[GRASSLIST:2271] Re: Poor quality PNG file driver output
Sun Jan 18 17:49:56 EST 2004
> I'm having trouble outputting images from the PNG file driver - the
> quality of the resulting .png images is very poor.  I put together the
> maps that I want to output using:
> d.mon start=PNG
> d.mon select=PNG
> d.rast dem.relshade
> d.mon stop=PNG
> This does NOT give me what I'd see in the grass monitor if I'd used
> d.mon start=x0 instead of the PNG driver.  The colors in the image are
> interpolated, not enough shades of grey, for instance, as if the color
> palette was very small.  Lots of blotchy colors, and no smooth
> transitions and  gradients.
> Markus, in your book you make the following reference on p. 187 in the
> section 8.1.3 on "Monitor output to PNG and HTML files"
> "If the Gd2.x library is installed the driver supports true color
> output"
> Because my images look like they don't have enough colors, I assumed
> this was the problem.  So, I installed the gd  2.0.9 library and tested
> it to make sure it was working.  I get the same poor quality images.  I
> AM setting the GRASS_TRUECOLOR=TRUE environment variable.
> What's going on here?  Why is the output from PNG file driver so
> different from the output from the GRASS monitor?
Did you recompile GRASS after installing GD 2.0?
maybe one of the following two scripts will be helpful.
Hamish
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040119/6ce5159f/d.out.png.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040119/6ce5159f/d.out.png-0001.obj
