[GRASSLIST:2277] Re: Poor quality PNG file driver output
Glynn Clements glynn.clements at virgin.net
Mon Jan 19 02:16:52 EST 2004
Jason Horn wrote:
> Thanks so much for your response.  I found your scripts elsewhere on
> the web and have already had a go at using them.  The PNG script uses
> the same commands that I was referring to, so the output is the same.
> The xwd script works better, but the output is still NOT a match to
> what I see on the screen in the GRASS monitor.  The xwd output tends to
> dither areas of flat color, so that's not acceptable either.
I have found xwd to be unreliable on true-colour displays. If you have
either ImageMagick or GIMP, both of those have a screen-grabbing
feature which can be used instead of xwd.
Glynn Clements <glynn.clements at virgin.net>
