[GRASSLIST:2310] Re: r.in.gdal : Unresolvable problems? -- Solved
Carl Brown cbsled at ncia.net
Wed Jan 21 12:23:33 EST 2004
So is there a working step-by-step procedure?
I have tried the recommended fixes without success up to this point.
As I understand it now, I should:
Uninstall gdal, but gdal does not have a "make uninstall".
What should I delete?
for gdal:
CFLAGS=-g ./configure --without-grass
For GRASS:
CFLAGS=-g ./configure --with-gdal=/usr/local/bin  (where gdal-config is located)
Then build gdal again with:
CFLAGS=-g ./configure --with-grass=???
The gdal configure --help says to point it to the "libgrass path", but
libgrass does not exist.
Carl Brown
Whitefield, NH USA
