[GRASSLIST:2388] code example plotRasterMap from progmangrass50
Daniel Isenegger disen at geo.unizh.ch
Thu Jan 29 06:32:50 EST 2004
Hi
I try to get started with Grass programming with the code example on
p.264 from the progmangrass50.After getting help concerning the
Gmakefile i got stuck now:
when executing the executable, it stops with (i guess it hangs)
B
(after some typing some returns)
=full_screen
full_screen : unknown error
Bfull_screen
ERROR: Current graphics frame not available
I tried to debug the error, but i get deeper and deeper into the source
code:
framestack (with backtrace in gdb). somewhere in D_get_cur_wind it stops.
#0  D_get_cur_wind (name=0xbfffed70 "\200ý\034@") at window.c:153
#1  0x0804ac76 in D_setup (clear=1) at setup.c:32
#2  0x080498db in plot_raster_map (name=0x8062bf4 "elevation.dem",
    mapset=0x8062bea "PERMANENT", overlay=0) at plotRasterMap.c:12
#3  0x080498ae in main (argc=1, argv=0x1) at ctest.c:18
#4  0x400b58ae in __libc_start_main () from /lib/libc.so.6
- I work with Grass 5.0.3 (compiled from source). Since I'm not root,
i've installed grass on custom paths.
- I use tcsh. I've experimented to start Grass from bash, but this
didn't help
- I've read smth about writing a graphics driver (p. 407 in
progmangrass50), i tried to look a the mentioned files, e.g
Gisbase/src.D/devices or GENERIC, but in my installation there not
there. ???
I very much appreciate all advices
Thanks dani
ps this is my config-statement and the config-info from GRASS (I doubt
if i configured grass wrong)
./configure --prefix=/data/gis/nfp48/nfp48/ipodlas0.1/grass
--with-bindir=/data/gis/nfp48/nfp48/ipodlas0.1/grass --without-gd
--with-postgres
--with-postgres-includes=/data/gis/nfp48/nfp48/ipodlas0.1/lib/postgresql-7.4.1/include/
--with-postgres-libs=/data/gis/nfp48/nfp48/ipodlas0.1/lib/postgresql-7.4.1/lib/
--with-odbc
--with-odbc-includes=/data/gis/nfp48/nfp48/ipodlas0.1/lib/unixODBC-2.2.7/include/
--with-odbc-libs=/data/gis/nfp48/nfp48/ipodlas0.1/lib/unixODBC-2.2.7/lib
--without-fftw --enable-socket | & tee compileOutput.log
Copying config.status to config.status.i686-pc-linux-gnu
GRASS is now configured for i686-pc-linux-gnu
  Source directory:
/data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5sources/grass-5.0.3
  Build directory:
/home/gis/disen/links/ipodlas0.1/grass/grass5sources/grass-5.0.3
  Installation directory:    /data/gis/nfp48/nfp48/ipodlas0.1/grass/grass5
  C compiler:                gcc -g -O2
  FORTRAN compiler:          g77
  NVIZ:                       yes
  X11 support:                yes
  DBM support:                no
  JPEG support:               yes
  TIFF support:               yes
  PNG support:                yes
  GD support:                 no
  Tcl/Tk support:             yes
  PostgreSQL support:         yes
  OpenGL(R) support:          yes
  ODBC support:               yes
  FFTW support:               no
  BLAS support:               no
  LAPACK support:             no
  Motif support:              no
  FreeType support:           no
  GLw support:                no
  NLS support:                no
  Readline support:           no
