[GRASSLIST:3771] Re: unable to initialize GDAL bridge
Glynn Clements glynn.clements at virgin.net
Mon Jun 28 17:45:46 EDT 2004
Grant Yip wrote:
> Hi, I'm a grass beginner and am running into a problem with
> r.in.gdal.  Whenever I try to import a file, I receive the following error:
> GBBridgeInitialize() failed to find an suitable GDAL .DLL/.so file.
[snip]
> I am running Grass53 in Cygwin in Windows XP Pro.  The version of GDAL that
> I built from source is 1.2.1.  Thanks in advance.
On Cygwin, you have to use the --with-gdal configure switch.
Glynn Clements <glynn.clements at virgin.net>
