[GRASSLIST:2980] Re: NViz: command not found
Richard Greenwood rich at greenwoodmap.com
Thu Mar 18 14:22:34 EST 2004
Matthew Tennant wrote:
> Hello Grasslist.
>                I have a problem -  occuring on the Windows port of GRASS
> (5.0.2) using the cygwin
> environment and XWindows driver. When I type nviz at the command prompt I
> get a "command not found" message.
> Searching my cygwin tree I see I only have one file called nviz, in
> usr/local/grass5/tcktkgrass/module, and it's only 1K.
> Does this mean I haven't installed nviz? If not how do I? Is it possible
> to install binaries only, or is compilation of source necessary?
You can download a binary distribution of Grass 5.0.3 for Cygwin XServer
which has a working Nviz from www.greenwoodmap.com/grass. In my
experience, Nviz does not work very in the "generic" or non-XWindows
environment.
Richard Greenwood
