[GRASSLIST:3348] Re: Compilation error in module: src/raster/r.in.gdal(ignored)
DrakeGis drakegis at dacafe.com
Tue May 4 19:14:11 EDT 2004
  Thanks Andrew for your message but I'm still having a lot of errors. The
log file correspoinding to
[.../src/raster/r.in.gdal/] gmake5 -i
  is the same I post in the previous e-mail.
 There are around 120 error from gdal.h and 40 from main.c.
 It seems to me, that probably I need to add some extra parameters to the
gmake5 command...
  Any alternative ?
  Thanks
   Drake
> compile with the gmake5 -i and related gmakelink -i option (these may be
> misspelled) within the gdal module  directory under grass5 src  stuff.
> The error messages (if any) will be more illuminating.
> DrakeGis wrote:
>>Hi,
>>  I download and compile Grass 5.0.3, and I recieve this message, after
>>the compilation. here is my error.log
>>GRASS GIS compilation log
>>Start of compilation: Tue May  4 05:38:31 EDT 2004
>>Errors:
>>Compilation error in module: src/raster/r.in.gdal (ignored)
>>End of compilation:   Tue May  4 05:42:01 EDT 2004
>>DONE generating GRASS GIS binary code
>>I try with
>>./configure --with-gdal
>>./configure --with-gdal='/usr/local/bin/gdal-configure'
>>./configure --with-gdal='/usr/local/bin'
>>and the rest of the options (tcltk, etc, etc). But all the three
>>alternatives generate the same error.log.
>>I have openev installed and it works. Also, I have libgdal1
>># slocate libgdal
>>/usr/local/lib/libgdal.1.1.so
>>The problem is that I need to work with some IMG files and r.in.gdal is
>>not in grass due to this error.
>>I also try to use gmake5 in order to compile the module... but I don't
>>know how to use it. According to the INSTALL file should be a simply
>>gmake5. I did a gmake5  in /scr/raster/r.in.gdal/ but there are a lot of
>>errors (I'm attaching gmake5.log, also following the INSTALL
>>instructions).
>>I will really thanks you for the help
>>  Drake
>>PS: I'm using Debian 3 SID, on a notebook Compaq Presario 2175US
>>This email was sent using http://cafemail.giscafe.com .
