[GRASSLIST:3344] Re: Compilation error in module: src/raster/r.in.gdal (ignored)
Andrew selkiesdad at twcny.rr.com
Tue May 4 07:39:11 EDT 2004
compile with the gmake5 -i and related gmakelink -i option (these may be
misspelled) within the gdal module  directory under grass5 src  stuff.
The error messages (if any) will be more illuminating.
DrakeGis wrote:
>Hi,
>  I download and compile Grass 5.0.3, and I recieve this message, after
>the compilation. here is my error.log
>GRASS GIS compilation log
>Start of compilation: Tue May  4 05:38:31 EDT 2004
>Errors:
>End of compilation:   Tue May  4 05:42:01 EDT 2004
>DONE generating GRASS GIS binary code
>I try with
>./configure --with-gdal
>./configure --with-gdal='/usr/local/bin/gdal-configure'
>./configure --with-gdal='/usr/local/bin'
>and the rest of the options (tcltk, etc, etc). But all the three
>alternatives generate the same error.log.
>I have openev installed and it works. Also, I have libgdal1
># slocate libgdal
>/usr/local/lib/libgdal.1.1.so
>The problem is that I need to work with some IMG files and r.in.gdal is
>not in grass due to this error.
>I also try to use gmake5 in order to compile the module... but I don't
>know how to use it. According to the INSTALL file should be a simply
>gmake5. I did a gmake5  in /scr/raster/r.in.gdal/ but there are a lot of
>errors (I'm attaching gmake5.log, also following the INSTALL
>instructions).
>I will really thanks you for the help
>  Drake
>PS: I'm using Debian 3 SID, on a notebook Compaq Presario 2175US
>This email was sent using http://cafemail.giscafe.com .
