[GRASSLIST:3414] Re: 60,000 Vectors and Nothing's On
Markus Neteler neteler at itc.it
Fri May 14 11:24:48 EDT 2004
On Thu, May 13, 2004 at 09:39:58AM -0500, Scot Wilcoxon wrote:
> > Maybe the default color is black and you need to change the color to
> > white or yellow... Another possibility is that your default region does
> > not include the are you are trying to map.
> I had already defined the region to match the map.
> I tried it again, and now the map is visible.
> I suggest that "Plotting...Done" is not sufficient feedback.
> "Plotting...No points within display region...Done" would help.
This is already implemented in GRASS 5.7...
Markus
