[GRASSLIST:3519] Re: Geophysics modules for GRASS
Benjamin Ducke benducke at compuserve.de
Thu May 27 14:09:18 EDT 2004
Well, that's great news. Actually, I feel pretty comfortable
about my skills when it comes to GRASS programming and user
interface/API design, but I am not much of physicists,
so I am glad to hear that you and your colleagues will provide
all this support for the hard-core math stuff.
I agree that we should reuse as much existing functionality
as posssible. It's really just a matter of having all three,
a functional C API, a scripting interface and a set of
modules with a unified interface for the end user.
What is upward and downward correction?
On Thu, 27 May 2004 10:27:26 -0600
Craig Funk <funkmeister at lynxseismicdata.com> wrote:
> Hello, I really appreciate all the input and interest wrt geophysical
> applications in GRASS. Benjamin, I look forward to seeing the first
> version of your white paper. I live and work in Calgary Canada where
> there are many Geophysicists (highest density in the world). I have
> taken the liberty of contacting a few professors who are willing to
> review the white paper and offer some input on the best
> algorithm/approach to take for some of the modules.  My background is
> mostly software engineering and I have worked extensively with
> seismicity data and GIS systems. So while I have a working knowledge of
> potential fields, I am a little out of touch with the state of the art.
> For example, there seems to be a number of different approaches to
> incorporating DEM's into the terrain correction. My position on this is
> that I do not really want to implement the latest and greatest but
> rather the most robust and generally accepted approach.
> Other corrections like the free-air correction, latitude correction and
> reduction to the pole are pretty straight forward.
> I would also like to implement modules to do upward and downward
> continuation, any interest in this?
> Hamish has posted some good suggestions that I would like to follow.
> Most importantly I would like to use as much of the existing GRASS
> functionality as is possible. Not only will this reduce the amount of
> work required but it is good software engineering practice as it will
> minimize potential new bugs.
> Michael - the pictures you emailed are quite intriguing of the mag
> data. I do have a lot of experience with 3-D data in GIS systems. Back
> in the early 90's I was lead architect of a proprietary GIS system that
> is used for analysis of induced seismicity in hard-rock mines. I also
> implemented several modules to do iso-surface visualization and volume
> visualization. An image is attached:
