[GRASSLIST:3520] Re: Geophysics modules for GRASS
    Craig Funk
    funkmeister at lynxseismicdata.com
    Thu May 27 15:35:18 EDT 2004
Upward and downward continuation are essentially low and high pass
filters.
Upward continuation will suppress signals from short wavelength sources
at shallow depth,
and reveal the signals from long wavelength sources (regional or deep
sources).
Downward continuation is used to enhance the response of the source at
depth h by effectively
bringing the surface of measurement closer to the sources. This process
magnifies the short
wavelengths relative to the long wavelengths thus brings the shallow
sources more in focus. You could also think of this as a spatial
de-convolution.
One has to be very careful with downward continuation with respect to
the sampling rate of the survey and the sources of anomalies. For
example you should not downward continue a surface below the source of
an anomaly. There is no physical basis for this in the equations. Also
if you have some near surface anomalies that where not adequately
sampled, these signals will appear as lower frequency signals in the
data (aliased) and these signals will tend to blow up when you downward
continue. So you really have to "know your data" when you use these
techniques.
Craig
On 27-May-04, at 12:09 PM, Benjamin Ducke wrote:
> What is upward and downward correction?
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040527/d0effe0f/attachment.bin
