[GRASSLIST:4739] Re: E00 import
Markus Neteler neteler at itc.it
Mon Nov 8 12:31:01 EST 2004
On Sat, Nov 06, 2004 at 01:12:50AM -0700, Trevor Wiens wrote:
> I would like to import an E00 file into GRASS and put the linked database files into either dbf files or PostgreSQL. I've done some testing of ogr2ogr (with PostGIS), GRASS 5.3 and 5.7, e00pg, e002shp, and avcexport and althrough I can get the basic attribute fields, the additional tables and their attributes can't be retrieved.
> Is anyone aware of any tools available for Gnu/Linux that will do this?
Hi Trevor,
did you try
g.manual v.in.ogr
There is an example how to import E00. If it's not there, your GRASS 5.7 is
too old :-)
Regards
 Markus
