[GRASSLIST:4743] Re: E00 import
David Mahoney mahoneyd at unbc.ca
Tue Nov 9 01:50:28 EST 2004
Did you look at e00pg? It looks to output tables as sql files suitable for
Postgres.
It lives at http://e00pg.sourceforge.net/
Dave
On Mon, 8 Nov 2004, Markus Neteler wrote:
> On Sat, Nov 06, 2004 at 01:12:50AM -0700, Trevor Wiens wrote:
> > I would like to import an E00 file into GRASS and put the linked database files into either dbf files or PostgreSQL. I've done some testing of ogr2ogr (with PostGIS), GRASS 5.3 and 5.7, e00pg, e002shp, and avcexport and althrough I can get the basic attribute fields, the additional tables and their attributes can't be retrieved.
> > Is anyone aware of any tools available for Gnu/Linux that will do this?
> Hi Trevor,
> did you try
> g.manual v.in.ogr
> There is an example how to import E00. If it's not there, your GRASS 5.7 is
> too old :-)
> Regards
>  Markus
Dave
