[GRASSLIST:7355] Re: can't start GRASS 6.1 CVS (error in d.m)
Carlos Guâno Grohmann carlos.grohmann at gmail.com
Tue Jun 28 17:06:43 EDT 2005
So, I just treid to remove my compiled 6.1 and try with the
precompiled binaries) just to see if it works, I need to compile to
get access to 2Gb files), but.. same erros.
So I decided to try 6.0, but in the binaries section, I couldn't find
the good old tar.gz file and sh install script. Why? I must say I
didn't like it. I don't use Debian, Fedora, Suse, Mandrake... whata
about the other users with Slackware (like me), Gentoo, or any other
Linux distro that doesn't follow the rpm structure? I know that there
are ways to convert packages formats, but I never get good results
with them..
I just feel I have to say it....
Carlos
PS. I still have problems with GRASS 6.1 in my Slack 10.1, will keep trying...
On 6/28/05, Carlos Guâno Grohmann <carlos.grohmann at gmail.com> wrote:
> So i did, still nothing.. here goes the output...
> All myy locations and mapsets are valid (I was using then a week
> ago!), I even tried to create a new location, but got the same
> result...
> Carlos
> Welcome to GRASS 6.1.cvs (2005)
> GRASS homepage:                          http://grass.itc.it/
> This version running thru:               shell ()
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> Start the graphical user interface with: d.m &
> When ready to quit enter:                exit
> : Command not found
> Closing monitors.....
> Cleaning up temporary files.....
> done
> Goodbye from GRASS GIS
> On 6/28/05, Hamish <hamish_nospam at yahoo.com> wrote:
> > [cc grasslist]
> > > Nope.
> > > when I hit "esc-enter", I get "goodbye from GRASS-GIS".....
> > > maybe I should get the next CVS and see what happens?
> > > > > > > Hello all, I've just made a fresh install of GRASS 6.1 cvs,
> > > > > > > but when I try to start it I get this error msg:
> > > > > > > >guano at Valhalla:~$ Error in startup script: ERROR:
> > > > > > > >LOCATION_NAME
> > > > > > try removing ~/.grassrc6
> > > > > I did it, but still the same error.
> > > > can you start with 'grass -text' then start the GUI with "d.m"?
> > > Nope.
> > dumb question: does your location exist and is the mapset valid?
> > can you edit $GISBASE/etc/Init.sh and comment out the two "tput clear"
> > lines by adding a '#' to the start of line? That will stop the clearing
> > of the screen so if there is an error message you can see it.
> > $GISBASE is source/dist.i686-pc-linux-gnu/ or where you installed GRASS.
> > I don't think that would help unless you are using a very old copy.
> > Hamish
>               Carlos Henrique Grohmann - Guano
>   Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
> Linux User #89721  - carlos dot grohmann at gmail dot com
