[GRASSLIST:6276] Re: hdf and modis/aster
Maciek Sieczka werchowyna at epf.pl
Mon Mar 28 16:59:00 EST 2005
Ian
Anybody correct me if I'm wrong, but it seems that gdalinfo doesn't
recognize any info about the georefercing in your hdf - see "Coordinate
System is `'".
This is likely the reason of your problems. Either your file is not
georeferenced or there is something wrong with the hdf driver in gdal. Dig
the gdal mailing list and bugtracker for relevant info and consider bugging
gdal developers if needed then.
Maciek
----- Original Message -----
From: "Ian MacMillan" <ian_macmillan at umail.ucsb.edu>
To: "Maciek Sieczka" <werchowyna at epf.pl>
Cc: "GRASS Users Mailing List" <grasslist at baylor.edu>
Sent: Monday, March 28, 2005 4:39 PM
Subject: Re: [GRASSLIST:6258] hdf and modis/aster
> Here is the full output of gdalinfo.  Bit long, but I think it looks
> normal (I don't have a ton of experience with these files yet).
> GRASS 6.1.cvs (SonoraLL):~ > gdalinfo
> MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf
> Driver: HDF4/Hierarchical Data Format Release 4
> Size is 512, 512
> Coordinate System is `'
> Metadata:
>   title=MODIS/ASTER Airborne Simulator (MASTER) Level-1B Data
>   ExperimentName=Baja Mexico
>   FlightDate=29 April 1999
>   FlightNumber=99-003-02
>   GeographicArea=Tres Virgenes, Line 17
>   ClockUsedToProcess=GPS Clock
>   DataSliceNumber=17
>   FlightLineNumber=26
>   TotalFlightLines=40
>   Credits=Gumley & Hubanks/design, Fitzgerald & Cleven/modify, maintain
>   MASDataUsersGuideSource=MAS World Wide Web site at
> http://ltpwww.gsfc.nasa.gov/MAS/Home.html
>   VIS/NIRCountSensitivityAdjustment=No
>   DataVersion=Version  1.0
>   SoftwareVersion=Version 9.0
>   CalibrationVersion=Baja_4/16-5/26 ver 0.1
>   data_set= MASTER Baja Mexico
>   data_product=straight-line flight tracks
>   geog_flag=c
>   day_night_flag=d
>   granule_version=1
>   metadata_version=9a
>   producer_granule_id=Version  1.0    Baja_4/16-5/26 ver 0.1
>   data_quality=Excellent
>   granule_size=3.986607e+08
>   begin_date=19990429 214107
>   end_date=19990429 214403
>   lat_LL=27.49829
>   lon_LL=-112.6536
>   lat_UL=27.49786
>   lon_UL=-112.809
>   lat_UR=27.53468
>   lon_UR=-112.8115
>   lat_LR=27.53519
>   lon_LR=-112.6534
>   Principle_Investigator=Joann Stock (Caltech)
>   Other_Aircraft_Sensors=RC-30
>   CreationDate=24-Aug-99 00:16:00
> Subdatasets:
>    SUBDATASET_1_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":17
>   SUBDATASET_1_DESC=[4378x50] BlackBody1Temperature (16-bit integer)
>    SUBDATASET_2_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":18
>   SUBDATASET_2_DESC=[4378x50] BlackBody2Temperature (16-bit integer)
>    SUBDATASET_3_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":19
>   SUBDATASET_3_DESC=[4378x50] AnalogGain (16-bit integer)
>    SUBDATASET_4_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":20
>   SUBDATASET_4_DESC=[4378x50] AnalogOffset (16-bit integer)
>    SUBDATASET_5_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":21
>   SUBDATASET_5_DESC=[4378x50] BlackBody1Counts (16-bit integer)
>    SUBDATASET_6_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":22
>   SUBDATASET_6_DESC=[4378x50] BlackBody2Counts (16-bit integer)
>    SUBDATASET_7_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":23
>   SUBDATASET_7_DESC=[4378x50] Head1Counts (16-bit integer)
>    SUBDATASET_8_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":24
>   SUBDATASET_8_DESC=[4378x50] Head2Counts (16-bit integer)
>    SUBDATASET_9_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":25
>   SUBDATASET_9_DESC=[4378x50] Therm1Temperatures (16-bit integer)
>    SUBDATASET_10_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":26
>   SUBDATASET_10_DESC=[4378x50] Therm2Temperatures (16-bit integer)
>    SUBDATASET_11_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":27
>   SUBDATASET_11_DESC=[4378x50] Therm3Temperatures (16-bit integer)
>    SUBDATASET_12_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":28
>   SUBDATASET_12_DESC=[4378x50] Therm4Temperatures (16-bit integer)
>    SUBDATASET_13_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":29
>   SUBDATASET_13_DESC=[4378x50] CalibrationSlope (32-bit floating-point)
>    SUBDATASET_14_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":30
>   SUBDATASET_14_DESC=[4378x50] CalibrationIntercept (32-bit
> floating-point)
>    SUBDATASET_15_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":31
>   SUBDATASET_15_DESC=[4378x716] PixelLatitude (32-bit floating-point)
>    SUBDATASET_16_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":32
>   SUBDATASET_16_DESC=[4378x716] PixelLongitude (32-bit floating-point)
>    SUBDATASET_17_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":33
>   SUBDATASET_17_DESC=[4378x716] SensorZenithAngle (32-bit  floating-point)
>    SUBDATASET_18_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":34
>   SUBDATASET_18_DESC=[4378x716] SensorAzimuthAngle (32-bit
> floating-point)
>    SUBDATASET_19_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":35
>   SUBDATASET_19_DESC=[4378x716] SolarZenithAngle (32-bit floating-point)
>    SUBDATASET_20_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":36
>   SUBDATASET_20_DESC=[4378x716] SolarAzimuthAngle (32-bit  floating-point)
>    SUBDATASET_21_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":43
>   SUBDATASET_21_DESC=[4378x50x716] CalibratedData (16-bit integer)
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,  512.0)
> Upper Right (  512.0,    0.0)
> Lower Right (  512.0,  512.0)
> Center      (  256.0,  256.0)
> On Mar 26, 2005, at 3:24 AM, Maciek Sieczka wrote:
>> Ian
>> What does gdalinfo say about your hdf4 file? I've had an issue that  hdf4
>> "Aster relative DEM" was not recongnized as georeferenced in  newer Gdal
>> versions due to changes in the hdf driver. Maybe that is your case too?
>> Maciek
>> ----- Original Message ----- From: "Ian W. Macmillan"
>> To: <grasslist at baylor.edu>
>> Sent: Friday, March 25, 2005 11:14 PM
>> Subject: [GRASSLIST:6258] hdf and modis/aster
>>> Hi all, I am trying to import some MASTER data (combined MODIS and
>>> ASTER) that is an hdf4 file (it should have the same exact format as
>>> MODIS data). After realizing that I need to import the subdatasets
>>> (which import fine into an XY location), I have run into a problem. It
>>> seems that the data I want is in one subdataset, but the latitudes and
>>> longitudes are in separate subdatasets. How can I import this so that
>>> the data I want is actually georeferenced?
>>> I tried gdal_translate on a whim (gdal_translate -of GTiff -b 1
>>> subdataset myfile.tif), but I ended up with a geotiff that either  gives
>>> me an error of "cellhd.proj = 0 (unreferenced)" or if r.in.gdal -o
>>> "G_set_window(): Illegal latitude for South".
>>> Anyone run into this before?
>>> Thanks,
>>> Ian
>>> PS Using Mac 10.3.8, Grass 6.1cvs (march 22)
>>> Ian MacMillan
>>> Geological Sciences-UCSB
>>> "insert witticism here"
