[GRASSLIST:6279] Re: hdf and modis/aster
Michael Barton michael.barton at asu.edu
Tue Mar 29 01:46:47 EST 2005
According to the gdal maintainer (a few months back), there are problems
with the GCP and related data in Modis hdf files. So you can't use gdalwarp
to georeference them. The georeferenceing data in Terra ASTER hdf files is
OK. My r.in.aster script will georeference and import these data.
Michael
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
> From: Ian MacMillan <ian_macmillan at umail.ucsb.edu>
> Date: Mon, 28 Mar 2005 06:39:19 -0800
> To: Maciek Sieczka <werchowyna at epf.pl>
> Cc: GRASS Users Mailing List <grasslist at baylor.edu>
> Subject: [GRASSLIST:6269] Re: hdf and modis/aster
> Here is the full output of gdalinfo.  Bit long, but I think it looks
> normal (I don't have a ton of experience with these files yet).
> GRASS 6.1.cvs (SonoraLL):~ > gdalinfo
> MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf
> Driver: HDF4/Hierarchical Data Format Release 4
> Size is 512, 512
> Coordinate System is `'
> Metadata:
>    title=MODIS/ASTER Airborne Simulator (MASTER) Level-1B Data
>    ExperimentName=Baja Mexico
>    FlightDate=29 April 1999
>    FlightNumber=99-003-02
>    GeographicArea=Tres Virgenes, Line 17
>    ClockUsedToProcess=GPS Clock
>    DataSliceNumber=17
>    FlightLineNumber=26
>    TotalFlightLines=40
>    Credits=Gumley & Hubanks/design, Fitzgerald & Cleven/modify, maintain
>    MASDataUsersGuideSource=MAS World Wide Web site at
> http://ltpwww.gsfc.nasa.gov/MAS/Home.html
>    VIS/NIRCountSensitivityAdjustment=No
>    DataVersion=Version  1.0
>    SoftwareVersion=Version 9.0
>    CalibrationVersion=Baja_4/16-5/26 ver 0.1
>    data_set= MASTER Baja Mexico
>    data_product=straight-line flight tracks
>    geog_flag=c
>    day_night_flag=d
>    granule_version=1
>    metadata_version=9a
>    producer_granule_id=Version  1.0    Baja_4/16-5/26 ver 0.1
>    data_quality=Excellent
>    granule_size=3.986607e+08
>    begin_date=19990429 214107
>    end_date=19990429 214403
>    lat_LL=27.49829
>    lon_LL=-112.6536
>    lat_UL=27.49786
>    lon_UL=-112.809
>    lat_UR=27.53468
>    lon_UR=-112.8115
>    lat_LR=27.53519
>    lon_LR=-112.6534
>    Principle_Investigator=Joann Stock (Caltech)
>    Other_Aircraft_Sensors=RC-30
>    CreationDate=24-Aug-99 00:16:00
> Subdatasets:
> SUBDATASET_1_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":17
>    SUBDATASET_1_DESC=[4378x50] BlackBody1Temperature (16-bit integer)
> SUBDATASET_2_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":18
>    SUBDATASET_2_DESC=[4378x50] BlackBody2Temperature (16-bit integer)
> SUBDATASET_3_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":19
>    SUBDATASET_3_DESC=[4378x50] AnalogGain (16-bit integer)
> SUBDATASET_4_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":20
>    SUBDATASET_4_DESC=[4378x50] AnalogOffset (16-bit integer)
> SUBDATASET_5_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":21
>    SUBDATASET_5_DESC=[4378x50] BlackBody1Counts (16-bit integer)
> SUBDATASET_6_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":22
>    SUBDATASET_6_DESC=[4378x50] BlackBody2Counts (16-bit integer)
> SUBDATASET_7_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":23
>    SUBDATASET_7_DESC=[4378x50] Head1Counts (16-bit integer)
> SUBDATASET_8_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":24
>    SUBDATASET_8_DESC=[4378x50] Head2Counts (16-bit integer)
> SUBDATASET_9_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":25
>    SUBDATASET_9_DESC=[4378x50] Therm1Temperatures (16-bit integer)
> SUBDATASET_10_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":26
>    SUBDATASET_10_DESC=[4378x50] Therm2Temperatures (16-bit integer)
> SUBDATASET_11_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":27
>    SUBDATASET_11_DESC=[4378x50] Therm3Temperatures (16-bit integer)
> SUBDATASET_12_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":28
>    SUBDATASET_12_DESC=[4378x50] Therm4Temperatures (16-bit integer)
> SUBDATASET_13_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":29
>    SUBDATASET_13_DESC=[4378x50] CalibrationSlope (32-bit floating-point)
> SUBDATASET_14_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":30
>    SUBDATASET_14_DESC=[4378x50] CalibrationIntercept (32-bit
> floating-point)
> SUBDATASET_15_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":31
>    SUBDATASET_15_DESC=[4378x716] PixelLatitude (32-bit floating-point)
> SUBDATASET_16_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":32
>    SUBDATASET_16_DESC=[4378x716] PixelLongitude (32-bit floating-point)
> SUBDATASET_17_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":33
>    SUBDATASET_17_DESC=[4378x716] SensorZenithAngle (32-bit
> floating-point)
> SUBDATASET_18_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":34
>    SUBDATASET_18_DESC=[4378x716] SensorAzimuthAngle (32-bit
> floating-point)
> SUBDATASET_19_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":35
>    SUBDATASET_19_DESC=[4378x716] SolarZenithAngle (32-bit floating-point)
> SUBDATASET_20_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":36
>    SUBDATASET_20_DESC=[4378x716] SolarAzimuthAngle (32-bit
> floating-point)
> SUBDATASET_21_NAME=HDF4_SDS:
> UNKNOWN:"MASTERL1b_9900302_26_19990429_2141_2144_V01.1.hdf":43
>    SUBDATASET_21_DESC=[4378x50x716] CalibratedData (16-bit integer)
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,  512.0)
> Upper Right (  512.0,    0.0)
> Lower Right (  512.0,  512.0)
> Center      (  256.0,  256.0)
> On Mar 26, 2005, at 3:24 AM, Maciek Sieczka wrote:
>> Ian
>> What does gdalinfo say about your hdf4 file? I've had an issue that
>> hdf4 "Aster relative DEM" was not recongnized as georeferenced in
>> newer Gdal
>> versions due to changes in the hdf driver. Maybe that is your case too?
>> Maciek
>> ----- Original Message ----- From: "Ian W. Macmillan"
>> To: <grasslist at baylor.edu>
>> Sent: Friday, March 25, 2005 11:14 PM
>> Subject: [GRASSLIST:6258] hdf and modis/aster
>>> Hi all, I am trying to import some MASTER data (combined MODIS and
>>> ASTER) that is an hdf4 file (it should have the same exact format as
>>> MODIS data). After realizing that I need to import the subdatasets
>>> (which import fine into an XY location), I have run into a problem. It
>>> seems that the data I want is in one subdataset, but the latitudes and
>>> longitudes are in separate subdatasets. How can I import this so that
>>> the data I want is actually georeferenced?
>>> I tried gdal_translate on a whim (gdal_translate -of GTiff -b 1
>>> subdataset myfile.tif), but I ended up with a geotiff that either
>>> gives
>>> me an error of "cellhd.proj = 0 (unreferenced)" or if r.in.gdal -o
>>> "G_set_window(): Illegal latitude for South".
>>> Anyone run into this before?
>>> Thanks,
>>> Ian
>>> PS Using Mac 10.3.8, Grass 6.1cvs (march 22)
>>> Ian MacMillan
>>> Geological Sciences-UCSB
>>> "insert witticism here"
