[GRASSLIST:8857] Re: HDF files?
Michael Barton michael.barton at asu.edu
Thu Nov 3 11:02:00 EST 2005
I tried to import Terra ASTER hdf files using the latest gdalwarp and my
r.in.aster script last week, after compiling the latest version (1.3.1) of
gdal. It still gives an error that gdal cannot read the projection info in
the ASTER hdf's. This has been an issue since 1.2.7 (version 1.2.6 still
works fine on my Mac).
I haven't tried r.in.gdal, but suspect that I'd have similar problems
(please correct me if wrong!).
Is there a fix or workaround to this? All ASTERs are in WGS84, UTM
projection (the zone varies of course).
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Thu, 3 Nov 2005 14:44:44 +1300
> To: Jonathan Greenberg <jgreenberg at arc.nasa.gov>
> Cc: <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:8849] Re: HDF files?
>> Is there any way to get HDF files into GRASS?  I saw there is an
>> r.in.hdf command, but Grass 6.0.1 on MacOS X is throwing and error
>> when I try it: command not found
> Use r.in.gdal, but GDAL must be built using the --with-hdf4 switch.
> http://www.remotesensing.org/gdal/frmt_hdf4.html
> try "gdal_translate --formats" and check for:
>   HDF4 (ro): Hierarchical Data Format Release 4
>   HDF4Image (rw+): HDF4 Dataset
> or just "gdalinfo <dataset>" and see if it understands the file(s).
> "r.in.gdal -f in=dummy out=dummy" will also list supported GDAL formats.
> (often there will be about 50 of them)
> Hamish
