[GRASSLIST:8867] RE: table of x, y and z points
Hamish
hamish_nospam at yahoo.com
Thu Nov 3 18:48:03 EST 2005
On Thu, 3 Nov 2005 19:51:29 -0000 (WET)
"Tiago Salgueiro" <1010664 at isep.ipp.pt> wrote:
> Like you said I try the following:
> $v.in.ascii -z input=/home/tiago/teste output=teste_out format=point
> fs=tab skip=1 columns='x double precision, y double precision, z
> double precision, cat int' \ x=1 y=2 z=3 cat=0
> with teste file like this:
> x y z
> 1 1 1
> 2 2 2
> 3 3 3
> 4 4 2
> 5 5 1
> GRASS just didn't made anything. Do you have some idea about what is
> wrong?
You need to cut and paste exact output. "just didn't made anything"
doesn't give us much to go by. Was there an error message? Seems to run
ok but 0 features created? Output map is there, but when you look at
v.info it is empty? Need to run "g.region vect=teste_out" before d.vect?
Hamish
