[GRASSLIST:8898] Re: orthorectification of Quickbird satellite images
Dan Gavin dgavin at uvm.edu
Fri Nov 4 23:40:59 EST 2005
Ian,
Thanks for the comment.  My reading and experience with i.points and
i.rectify is that is does a rectification for planar surfaces, but
can't take terrain displacement into account.  i.ortho.photo does use
a DEM in conjunction with rectification, but it is tailored to aerial
photos, not satellite images.  Low elevation satellite images (> 20
degrees from nadir) accentuate the effect of topography.
Dan
At 5:20 PM -0800 11/4/05, Ian MacMillan wrote:
>Dan, I am not sure about i.points3, but i.points and i.rectify does
>work.  I think you will still need a higher resolution DEM for your
>elevation correction (depending on the resolution you want for your
>satellite imagery).  Those are sometimes hard to obtain for large
>parts of the world.
>Hope this helps,
>Ian
>On Nov 4, 2005, at 3:42 PM, Dan Gavin wrote:
>>Hello all:
>>I would like to orthorectify some high-resolution Quickbird images,
>>taken 20 degrees off-nadir.  They are in a mountainous region, and
>>I need fairly high positional accuracy.  While these images are
>>distributed as geoTIFFs, elevational distortions have not been
>>removed (their ortho product is based on a 90 meter DEM).
>>Searching the list archives, I see a suggestion to use i.points3
>>and i.rectify3.  Are these functions available in GRASS 6.1?  Any
>>other suggestions, including other software?
>>Many thanks,
>>Dan
>>Dan Gavin
>>Research Associate
>>University of Vermont
>>Botany and Agricultural Biochemistry
>>120B Marsh Life Science
>>109 Carrigan Dr.
>>Burlington, VT 05405-0086
>What happens if a big asteroid hits Earth? Judging from realistic
>simulations involving a sledge hammer and a common laboratory frog,
>we can assume it will be pretty bad.
>  - Dave Barry
>This message has been scanned by Postini anti-virus software.
Dan Gavin
Research Associate
109 Carrigan Dr.
