[GRASSLIST:9107] Mask
Atif Rajan atif at lynxseismicdata.com
Wed Nov 16 16:43:46 EST 2005
Dear readers,
Can some help me with the following please:
GRASS6.0  OS: Suse 9.1
I have a Grass location and a Mapset with a raster(MAP_rast) and a vector
(MAP_vect)
I converted the vector to raster using v.to.rast (MAP1)
I generated a surface as follows:
d.rast MAP1
g.region res=500
r.surf.contour -f input=MAP1 output=MAP_surf
What I am trying to do is to generate this surface only where there are
contours and not beyond. How do I do this?
thank you.
Atif
