[GRASSLIST:9180] [Fwd: Re: GRASS 6 in a nutshell tutorial]
Luigi Ponti lponti at infinito.it
Mon Nov 21 20:20:05 EST 2005
Thanks Ian and Hamish,
I was eventually able to fix the problem by downloading a unprojected
California layout shapefile (form <www.census.gov>) and then importing
it via v.proj in the location with the digital elevation map. Apparently
the official shapefile of California layout has a wrong latitude.
Next step is to connect the output table of the population model
(population densities at weather stations) to the map I have just
created. This would hopefully result in an interpolated raster.
Hamish suggested the following:
Load in site data with v.in.ascii & interpolate between sites with v.surf.rst.
According to the manual v.in.ascii uses the | separator. Is it worth to manually put the file in that format or do you think is better to convert it in a database to connect with a specific command?
Thank you,
Luigi
-------- Original Message --------
Subject: 	[GRASSLIST:9087] Re: GRASS 6 in a nutshell tutorial
Date: 	Wed, 16 Nov 2005 00:03:56 +0100
To: 	Ian MacMillan <ian_macmillan at umail.ucsb.edu>
CC: 	Hamish <hamish_nospam at yahoo.com>, GRASSLIST at baylor.edu
References: 	<43667143.6030900 at infinito.it> <43689B17.9040302 at itc.it>
<436AA43E.2030709 at infinito.it>
<2a710737c668a9cf27237f3236b55a2f at umail.ucsb.edu>
<43724994.2070505 at infinito.it>
<20051110181214.21c19d6a.hamish_nospam at yahoo.com>
<43790A77.2050108 at infinito.it>
<29ded48ac16bbfc3492e5eff023d357a at umail.ucsb.edu>
Dear Ian,
the original metadata of my state outline shapefile is:
PROJCS["unnamed",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS
1980",6378137,298.257222101,AUTHORITY["EPSG",7019]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG",6269]],PRIMEM["Greenwich",0,AUTHORITY["EPSG",8901]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG",9108]],AXIS["Lat","NORTH"],AXIS["Long","EAST"],AUTHORITY["EPSG",4269]],PROJECTION["Albers"],PARAMETER["standard_parallel_1",34],PARAMETER["standard_parallel_2",40.5],PARAMETER["latitude_of_center",0],PARAMETER["Central_Meridian",-120],PARAMETER["False_Easting",0],PARAMETER["False_Northing",-4000000],UNIT["m",1]]
Based on this, following direction in the GRASS/cygwin
installation page
http://geni.ath.cx/grass.html#toc15
I have created a dummy vector for reprojection of the
raster DEM of western USA - e10g tile. Then I created a
new location from EPSG code to match the vector .shp state
outline file, and I have imported both the dummy raster
DEM via "v.proj" and the vector state outline via
"v.in.ogr".
Using "gdalinfo" on the original raster file (e10g),
originated the following output:
gdalinfo c:/cygwin/home/andy/DEM_data/e10g
Driver: EHdr/ESRI .hdr Labelled
Size is 10800, 6000
Coordinate System is `'
Origin = (-180.000000,50.000000)
Pixel Size = (0.00833333,-0.00833333)
Corner Coordinates:
Upper Left  (-180.0000000,  50.0000000)
Lower Left  (-180.0000000,   0.0000000)
Upper Right ( -90.0000000,  50.0000000)
Lower Right ( -90.0000000,   0.0000000)
Center      (-135.0000000,  25.0000000)
Band 1 Block=10800x1 Type=Int16, ColorInterp=Undefined
  NoData Value=-500
Do you see anything wrong?
In addition, I tried to import v.in.e00 (after adding the
required .exe file in the bin folder of GRASS) but I have
not been successful yet.
Regards and thanks,
Luigi
On Mon, 14 Nov 2005 18:31:43 -0800
 Ian MacMillan <ian_macmillan at umail.ucsb.edu> wrote:
> Luigi, if you look at r.info and v.info, you will only
>find the  projection information of your location, not
>necessarily the  projection/datum/etc. information of the
>original data (I believe).  Do  you have the original
>metadata?  If not, try running gdalinfo on your  original
>data files to determine their original projection info.
> man gdalinfo
> will give you the correct syntax.
> G'luck
> Ian
> On Nov 14, 2005, at 2:06 PM, Luigi Ponti wrote:
>> Thanks Amish,
>> looking at v.info and r.info, it seems the two maps have
>>the same
>> projection (see below). However, when looking at the
>>output "d.where
>> -w" for a sample map point (the San Francisco Bay), the
>>longitude is
>> very different in the two maps:
>>                                                   WGS84
>>Co-ordinates
>>             EAST:             NORTH:               LON:
>>             -191114.6346037    -24240.66895625
>> 143:03:58.588289W
>> 29:24:27.1
>> (San Francisco Bay on the California State vector layer
>>- WRONG)
>>  1839139.30311877    663981.00484798  122:19:50.783112W
>>  37:57:48.1
>> (San Francisco Bay on the Elevation Model raster layer -
>>CORRECT)
>> Do you think this could be due to an error in the import
>>process or
>> should I just look for another vector map?
>> Thanks again,
>> Luigi
>> v.info map=state layer=1
>> | Layer:    state                          Organization:
>> | Mapset:   luigi                          Source Date:
>> | Location: Cal_nad83-zone3                Name of
>>creator:
>> | Database: /home/andy
>> | Title:
>> | Map Scale:  1:1
>> | Map format: native
>> |   Type of Map:  Vector (level: 2)
>> |   Number of points:       0               Number of
>>areas:      51
>> |   Number of lines:        0               Number of
>>islands:    48
>> |   Number of boundaries:   59              Number of
>>faces:      0
>> |   Number of centroids:    51              Number of
>>kernels:    0
>> |   Map is 3D:              0
>> |   Number of dblinks:      1
>> |   Projection: Lambert Conformal Conic (zone 0)
>> |            N: 922206.900    S: -701781.905
>> |            E: 1043412.917     W: -374425.808
>> |            B: 0.000         T: 0.000
>> |   Digitize threshold: 0.00000
>> |   Comments:
>> r.info map=e10g at PERMANENT
>> | Layer:    e10g                           Date: Tue Nov
>> 8 17:25:24
>> 2005    |
>> | Mapset:   PERMANENT                      Login of
>>Creator: andy
>> | DataBase: /home/andy
>> | Title:     ( e10g )
>> |   Type of Map:  raster              Number of
>>Categories: 5443
>> |   Data Type:    CELL
>> |   Rows:         7192
>> |   Columns:      11628
>> |   Total Cells:  83628576
>> |            N:    3353466    S:   -3838238   Res:
>>999.95884316
>> |            E:    6073284    W:   -5555183   Res:
>>1000.04016168
>> |   Range of data:    min =  -84 max = 5443
>> |   Data Source:
>> |   Data Description:
>> |    generated by r.proj
>> Hamish wrote:
>>>> I have imported both the vector and the raster with
>>>>minimum trouble,
>>>> since the first has a .prj file which GRASS recognized,
>>>>and the
>>>> second
>>>> had a detailed import tutorial in the cygwin-GRASS
>>>>install page.
>>>> However, despite the fact the the two layers supposedly
>>>>have the
>>>> same NAD83 projection info (I did not enter anything
>>>>manually), when
>>>> I try
>>>> to  display them together on a GRASS monitor, the state
>>>>layout is in
>>>> the  middle of the ocean compared to the elevation
>>>>raster.
>>>> Is there a way to overlap the two layers or to chek for
>>>>a coordinate
>>>> error?
>>> r.info and v.info will give you the map extents, you
>>>should then be
>>> able
>>> to figure out which is correct.
>>> Also try "d.where -w" to give you a lat/lon value for
>>>different parts
>>> of your map which you can compare to the map on the
>>>wall.
>>> Hamish
> What happens if a big asteroid hits Earth? Judging from
>realistic  simulations involving a sledge hammer and a
>common laboratory frog, we  can assume it will be pretty
>bad.
>  - Dave Barry
> This message has been scanned by Postini anti-virus
>software.
INFINITO ADSLFLAT 4 MEGA: SOLO 27,90 EURO AL MESE IVA INCLUSA IP STATICO, BANDA GARANTITA 256Kbps ANTIVIRUS E FIREWALL INCLUSI NEL PREZZO
http://adsl.infinito.it
