[GRASSLIST:9186] interpolation problems with GRASS
Feras O feras_o at yahoo.com
Tue Nov 22 09:46:16 EST 2005
Dear All:
   I am working on a GRASS 6 inorder to view my data in 3 dimension ISO Surface
I am using v.vol.rst for interpolation but I don't get results....I always get error messages:
here is my experiments. I always get a message incease DMIN, I do but I dont get results.
v.vol.rst input=octVector cellinp=survoctVector wcolumn=dbl_4 tension=40. smooth=0.1 segmax=50 dmin=0.010000 npmin=200 wmult=1.0 zmult=1.0 elev=ccc
65536 records selected from table
Points are too concentrated -- please increase DMIN
v.vol.rst input=octVector cellinp=survoctVector wcolumn=dbl_4 tension=40. smooth=0.1 segmax=50 dmin=2 npmin=200 wmult=1.0 zmult=1.0 elev=ccc
Warning: some points outside of region -- will ignore...
Warning: strip exists with insufficient data
Processing all selected output files
will require 40000 bytes of disk space for temp files
Warning: there are points outside specified region--ignored 28451 points (total points: 65536)
Warning: points are more dense than specified 'DMIN'--ignored 35481 points
Percent complete:
finished interpolating
I have dbf vector file composed of 5 columns :
   CAT, dbl_1 (lat) , dbl_2(long), dbl_3(Sea Depth), dbl_4 (Temprature)
following under is sample of my data:
60.394146|-60.344543|-38.880001|5.940000
60.394146|-60.344543|-39.080002|5.944000
60.394146|-60.344543|-38.980000|5.945000
60.394146|-60.344543|-38.980000|5.946000
60.394146|-60.344543|-39.080002|5.949000
60.394146|-60.344543|-38.980000|5.951000
60.394146|-60.344543|-39.080002|5.951000
60.394146|-60.344543|-38.880001|5.953000
actually , I don't know from where to start, I already transfer my data to vector  as above...I can see my map ..but what I need next to visualise the map in 3 dim...I have read many articles..but I dont get any advantage......I dont know
  I hope if you have some example related to send it to me...
  Thanks in advance
  Feras
Feras O <feras_o at yahoo.com> wrote:
Feras O <feras_o at yahoo.com> wrote: Dear Friends:
Since one month I am working on a GRASS 6 inorder to view my data in 3 dimension ISO Surface
I am using V.Vol.RST for interpolation but I don't get results....I always get error messages:
Percent complete:
I have dbf vector file composed of 5 columns : CAT, dbl_1 (lat) , dbl_2(long), dbl_3(Sea Depth), dbl_4 (Temprature)
        So far , I don't have any output,,please tell me what should I do.
many thanks
feras
  Yahoo! FareChase - Search multiple travel sites in one click.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051122/c47d99b6/attachment.html
