[GRASSLIST:8786] Re: proj_api.h
M S mseibel at gmail.com
Thu Oct 27 15:41:20 EDT 2005
as a follow up.......
the fedora core 4 RPM does not have the proj_api.h file, or at least doesnt
install it on the system.
when i did the proj4.4.9-1 from source tarball, all was good!
On 10/27/05, M S <mseibel at gmail.com> wrote:
> nice catch... its probably the proj-devel i need!
> On 10/27/05, Paul Kelly <paul-grass at stjohnspoint.co.uk > wrote:
> > Hello
> > On Thu, 27 Oct 2005, M S wrote:
> > > i see the configure flags to point it to the various proj external
> > areas,
> > > but i cant find this proj_api.h on my system at all except for in the
> > grass
> > > dir of gproj_api.h.
> > > i'm running FC4.
> > > i have proj 4.4.9-1 installed.
> > proj_api.h should come with PROJ.4. Maybe your operating system has
> > PROJ.4
> > split into separate development and runtime packages? You would need the
> > development package installed to compile GRASS. Just a guess. Someone
> > else
> > on the list could probably tell you a command to run to find out the
> > package
> > you need.
> > Paul
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051027/1b804c04/attachment.html
