[GRASS-user] run commands sequentially - help please
Tiago Salgueiro 1010664 at isep.ipp.pt
Thu Aug 3 11:24:25 EDT 2006
Hi all,
First of all you should know that I'm a beginner using GRASS.
I want to create a 3D map from a text file with coordinates. I think the
commands I will need are the following:
1 - v.in.ascii
2 - g.region
3 - v.surf.rst
4 - nviz
But I don't want to write the commands every time I want to see a map. So I
desire to do this sequentially. How can I do that? This way I'll only need
to run one command and the map happens.
Thanks for your help.
Cumprimentos/Best Regards,
Tiago Salgueiro
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060803/9013e56b/attachment.html
