[GRASS-user] v.in.ascii error: G_realloc
Markus Neteler neteler at itc.it
Fri Aug 4 07:25:56 EDT 2006
On Fri, Aug 04, 2006 at 12:30:45PM +0100, Praktikant/in2 ARP wrote:
> Hi,
> thanks Markus for your help. v.in.ascii is working fine now.
> But now I have problems with the created vector file. I think because of the
> missing topology.
> If I want to use the created vector file for example with v.patch I get the
> error:
> Cannot open old vector dtm1107_32 at Solothurn on level 2
> The same error if I use g.region vect=dtm1107_32
Only a couple of commands work without topology (to allow
working with large number of points). Would be good if
someone documents that in the Wiki.
> Another example: If I use v.surf.rst I get the error:
> Vector is not 3D
Maybe you forgot the -z setting in v.in.ascii to import as 3D?
Markus
