[GRASS-user] v.segment - how to use orthogonal offset?
Patton, Eric epatton at nrcan.gc.ca
Fri Aug 4 09:24:39 EDT 2006
Thanks, Markus, I'll check into it in more detail when I get back from the
field.
~ Eric.
-----Original Message-----
To: grassuser at grass.itc.it
Sent: 8/4/2006 6:46 AM
Subject: Re: [GRASS-user] v.segment - how to use orthogonal offset?
On Thu, Aug 03, 2006 at 03:08:58PM -0300, Patton, Eric wrote:
> Here's a text file I prepared for use as stdin for v.segment:
> P 1 2 100 100
> P 2 2 200 100
> P 3 2 300 100
> P 4 2 400 100
> The fourth column, according to the v.segment html page, is the
orthogonal
> offset from the input vector. But no matter what I make this value,
the
> output vector is never offset, it's always in the middle of the width
of the
> line. What am I doing wrong here?
Maybe nothing (not sure):
http://grass.itc.it/pipermail/grassuser/2005-December/031522.html
">> What does the extra, optional value <side offset> in v.segment
stands for?
 > The point placed in the give distance form the line.
 >> I couldn't get any differences by using this!
 > That would be bug, are you sure you use appropriate zoom
 > for given distance.
 It still doesn't work ...
I don't see any answer from Radim.
with
g.gisenv set="DEBUG=2"
you should see some related output how the file is parsed.
In the code I don't see that side_offset modifies offset1 or
offset2 (which it probably should).
Markus
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
