[GRASS-user] howto make my srtm-dem jump the GIS gap
William Kyngesburye woklist at kyngchaos.com
Wed Aug 9 14:46:05 EDT 2006
On Aug 9, 2006, at 11:55 AM, Rudolf Maurer wrote:
> Hi there!
> I tried Williams
> r.out.gdal in=dem out=dem.tif cre="COMPRESS=PACKBITS" type=Int16
> which looks OK:
> GRASS 6.0.1 (baydem):~ > r.out.gdal in=clean_alle out=clean_test.tif
> Writing format: GTiff
> Writing type:   Int16
> Input file size is 2400, 2400
> 0.Warning 1: Unable to export color table to GeoTIFF file.  Color
> tables
> can only be written to 1 band Byte or UInt16 GeoTIFF files.
> ..10...20...30...40...50...60...70...80...90...100 - done.
> Even though I used d.what.rast to check on the data-format, and I got
> floating point numbers (I guess due to interpolation):
> 10:48:07.5E 47:01:22.5N
> clean_alle in maurerr, quant   (2686)
> clean_alle in maurerr, actual  (2685.749512)
> What's the difference between those two values? What would be the
> common way to get this information?
when it's exported to the tiff, the rounded quant number is used.
The fillnulls step on the SRTM data made this into a float raster.
> TIF is 12MB. My QGIS 0.7.4 "Seamus" does have problems opening it...
> Tomorrow I can check what E$SRI says.
>> That is a good point. The 2 Gb limit is still a problem for file-
>> based data in ArcGIS. Rudolf, is your file around 2 Gb?
> Definitely not: ARC-Grids have under 30MB. I use 4 tiles of SRTM-Data,
> 2400 by 2400 cells in 9 arc seconds.
> Now Arc-Grid:
> I did
> GRASS 6.0.1 (baydem):~ > r.out.gdal in=clean_alle out=clean_test_arc
> type=Byte format=AAIGrid
> Writing format: AAIGrid
> Writing type:   Byte
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> File is 26 MB.
> Is type=Byte OK? I would not need big numbers though.
No, that will only give you up to 255 elevation and no negative
values (for the various below sea level depressions in the world).
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole.  Now what
does that remind me of?  Ah, yes - life."
- Marvin
