[GRASS-user] 'ARNing: Cannot open driver 'dbf"
Thu Dec 7 23:12:27 EST 2006
Raymond Fu wrote:
> Sorry, I work in a user level, and know not much about C.  Can you
> suggest me what the "special treatment"  and how to make the
> "special treatment" by command line or other ways so that the g.copy
> can be run without error?
(it's probably a bug in the code, you'll have to wait for a new version?)
they quick & very dirty way to copy a vector map is to go into
$MAPSET/vector/ and just copy the folder with the vector to something
named something else, then do the same with $MAPSET/dbf/$MAPNAME.dbf
using the same name, and finally update the $MAPSET/vector/$MAPNAME/dbln
file in a text editor.
Hamish
