[GRASSLIST:10243] Re: gismlegend.txt problem
Ing.Peter Misovic peter.misovic at gmail.com
Fri Feb 10 03:59:58 EST 2006
Hi Michael,
thank you for your suggestion, I'll try out to do that.
Peter
On 2/10/06, Michael Barton <michael.barton at asu.edu> wrote:
> This problem may happen to other people.
> In order to make a legend in the new GIS Manager, d.vect.thematic must
> create a text file containing legend parameters and give it a name that gism
> can recognize. So, I've had d.vect.thematic write these out to a file named
> gismlegend.txt in the user's default directory (usually the home directory).
> If you cannot write to your default directory--whatever it
> is--gismlegend.txt won't get written and the GIS Manager won't find it.
> See if you are getting this file written into your default directory. If
> not, try making sure the permissions are set to let you write in the
> directory.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: "Ing.Peter Misovic" <peter.misovic at gmail.com>
> > Date: Thu, 9 Feb 2006 23:35:42 +0100
> > To: grass list <GRASSLIST at baylor.edu>
> > Subject: [GRASSLIST:10232] gismlegend.txt problem
> > Dear all,
> > I have problem in GM2 during following process:
> > a.) open d.vect.thematic
> > b.) setting of all related parameters
> > c.) switch to grass monitor
> > d.) click on redraw icon (top-left)
> > d.) error occuring : couldn't open "gismlegend.txt": no such file or directory
> > Thank you,
> > Peter
