[GRASSLIST:10540] Re: Labels and ps.map
    Michael Barton
    michael.barton at asu.edu
    Thu Feb 23 23:39:58 EST 2006
Nick,
Point vector attribute display in d.m and gis.m is done by d.labels--with
original labels file prepared by v.label (or by hand).
There is a fair amount of control over the display possible. However, the
labels ultimately are rendered to the screen as rasters. Gis.m can output
the screen to EPS or a postscript device now (if you have ghostscript
installed). However, it is output as a postscript bitmap/raster image. If
you make your map display larger, it might give you higher resolution in the
final EPS.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Nick Cahill <ndcahill at facstaff.wisc.edu>
> Date: Tue, 21 Feb 2006 20:15:03 +0200
> To: GRASSLIST international <GRASSLIST at baylor.edu>
> Subject: [GRASSLIST:10492] Labels and ps.map
> Dear Grass Gurus,
> Is there a reason why d.m and gis.m can display point vector
> attributes as labels, but this can't be output to a postscript file;
> and ps.map has to rely on the - I assume, somewhat outdated - method
> of using a separate label file? Currently, to get labels to come out
> correctly in ps.map, I have to run ps.map, look at the postscript
> output, find that the labels are a bit too big or something, make a
> whole new label file with different parameters, and start again; and
> this usually takes a number of iterations. It would be much more
> convenient (for me at least, as a user) to have site labels be part
> of vector display within ps.map, so you could have e.g.
> vpoints vector
> type point or/and centroid
> layer # (layer number used with cats/where/sizecol options)
> cats list of categories (e.g. 1,3,5-7)
> where SQL where statement like: vlastnik = 'Cimrman'
> masked [y|n]
> color color
> fcolor color
> **attlabel (attribute column)
> **attlabelsize (in points or whatever)
> **font, color, etc.
> Or am I missing something obvious?
> Thank you,
> Nick Cahill
