[GRASSLIST:10565] Re: r.fillnulls
Maciek Sieczka werchowyna at epf.pl
Sat Feb 25 03:46:03 EST 2006
On Fri, 24 Feb 2006 16:28:02 +0000
"giglio.antonio at katamail.com" <giglio.antonio at katamail.com> wrote:
> Hi, i used r.in.srtm for building a DEM. I have joined images (1°x1°
> squares) using r.patch, and now i'm trying to fill "no data" holes in
> the map i obtained. I think to use r.fillnulls, but have the
> following error:
> r.fillnulls input=input_name output=srilanka.dem tension=40.
> smooth=0.1 Using tmp file r_fillnulls_3464
> Locating and isolating NULL areas...
> GRASS_INFO_ERROR(3474,1): invalid ellipsoid i
> \a in file PROJ_INFO in PERMANENT
Please post what Grass version you are using, g.proj -p output and the
contents of your_location/PERMANENT/PROJ_INFO file. Maybe it will help
to indicate the problem.
<snip>
Maciek
W polskim Internecie są setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
