[GRASSLIST:10618] Re: ARC FLOWDIRECTION vs GRASS
Dylan Beaudette dylan.beaudette at gmail.com
Mon Feb 27 21:48:50 EST 2006
On Monday 27 February 2006 05:31 pm, Jonathan Greenberg wrote:
> I'm trying to replicate preparation of data for the DHSVM hydro model in
> GRASS following an AML script, and I'm a bit confused why every GRASS
> module with flow direction computation produces a different output than the
> ARC one -- they even differ between themselves (e.g. r.watershed and
> r.terraflow). Does anyone know of a flow direction computation that
> produces the EXACT same outputs as ARC?  I'm not "judging" which one is
> better, I'm just trying to follow as closely as possible the first time
> around the "idealized" algorithm.
> --j
Good questions -- tough answers. I would be sceptical of suggesting that the
Arc-derived output is any better... but to the real subject:
Can you provide more information on the "type" of flow model used by the Arc
AML script? i.e. is it using D4,D8,Rho8,FRho8,DEMON,D-INF flow calculation?
note that D4,D8, and Rho8 are SFD (single input flow direction - single
output)
FD8,FRho8 are MFD (multiple input flow direction - single output)
DEMON and D-INF are similar in many ways, but not identical (multiple input
multiple output?) [1]
Each one of these different treatments of adjacent cells will influence the
output flow map/
Some examples in GRASS see man pages for each command
1. simplest case of the D8 flow direction, stored in new raster dir_d8 :
r.fill.dir in=elev_meters elev=e_filled direction=dir_d8
note that direction can be in the form of 0-360 or 1-8
2. example of the D-INF algorithm (vector output stored in new vector flow)
r.flow elevin=e_filled aspin=aspect flout=flow
3. example of MFD aka FRho8 :
r.terraflow....
note that the direction output will be from 0-255
[1] Wilson and Gallant. Terrain Analysis. 2000
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
