[GRASSLIST:9743] Re: vector corruption? after qgis session crash
Jaime Carrera jaicarrerahdez at yahoo.com
Fri Jan 6 09:40:02 EST 2006
Hi Dylan,
 I've had the same problem a couple of times and running v.build solved it before.  Maybe you could enter GRASS' digitize mode and exit without modifying your vector file?
 HTH,
 Jaime
Dylan Beaudette <dylan.beaudette at gmail.com> escribió: Hi,
After a QGIS editing session crash, the vector that i was editing now has a
small problem. when working with this vector i get the following warning:
d.vect pedons
D1/1: Info->size = 6481, Info->mtime = 1136524613
D1/1: coor size in head = 6452, real coor file size= 6481
WARNING: coor files of vector 'pedons at waypts' is larger than it should be
         (29 bytes excess).
this file seems to work, but the warning is annoying. I have tried v.build,
however this does not fix the problem. is there any quick way to fix this, or
am i going to have to export the vector to text, and re-import it ?
thanks in advance,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
__________________________________________________
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060106/33540626/attachment.html
