[GRASSLIST:9912] Re: Procedure that I followed for installing GRASS mapserver
Stephan Holl holl at gdf-hannover.de
Thu Jan 19 02:30:28 EST 2006
Hello Siddhesh,
On Wed, 18 Jan 2006 21:51:01 -0800 (PST) Siddhesh Bhatkar
<sid_grass at yahoo.com> wrote:
> Hello Stephan,
> I added the non-standard location of  grass library
> (in my case  ~bnagesh/grass-6.0.0/lib) to the
> Enviroment variable  LD_LIBRARY_PATH in my .bashrc
> file.
> ./configure --with-gdal=/usr/local/bin/gdal-config
> --with-grass=/home/bnagesh/grass-6.0.0/
> now creates the Makefile Successfully.
> But when i run the "make" command i get the following
> error:
> g++ -Wall -fPIC  -DUSE_CPL
> -DGRASS_GISBASE=\"/home/bnagesh/grass-6.0.0/\"
> -I/usr/local/include
> -I/home/bnagesh/grass-6.0.0//include   -c -o
> ogrgrassdatasource.o ogrgrassdatasource.cpp
> ogrgrassdatasource.cpp: In member function `int
> OGRGRASSDataSource::Open(const char*, int, int, int)':
> ogrgrassdatasource.cpp:212: error: cannot allocate an
> object of type `OGRGRASSLayer'
> ogrgrassdatasource.cpp:212: error:   because the
> following virtual functions are abstract:
> /usr/local/include/ogrsf_frmts.h:176: error:
> virtual OGRGeometry* OGRLayer::GetSpatialFilter()
> make: *** [ogrgrassdatasource.o] Error 1
I did not come accross this error-message.
It *could* be related to the fact that a GRASS6 CVS-snapshpt is needed
for making the GRASS-plugin of GDAL work, but I do not know for sure.
Can anybody confirm?
We always work with GRASS CVS-versions in production, so I have not
seen this errors.
Another starting-point could be the GRASS-development-mailinglist,
which dan be found here[1].
Best regards
	Stephan
[1] http://grass.itc.it/mailman/listinfo/grass5
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060119/a3b1943c/signature.bin
