[GRASSLIST:10025] which is the best method to calculate the distance between two points?
Patricio Antonio Toledo Peña patricioantoniotoledo at gmail.com
Fri Jan 27 09:50:54 EST 2006
dear grass list,
i have two points, they do not belong to a vector map, i have found that i
can obtain the distance (in UTM and LAT/LONG locations) with this (ugly)
trick
grass$ r.profile map=rmap profile=x1,y1,x2,y2 2> temp_file
grass$ distance=$(awk '/length/{print $4}' < temp_file)
this method needs a query to a raster map, which is unnecessary, is
something like d.measure available in r.* commands?
Thanks in advance
Patricio Toledo
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060127/884bba46/attachment.html
