[GRASSLIST:10032] Re: which is the best method to calculate the distance between two points?
Odoardo Zecca odoardo.zecca at gmail.com
Sat Jan 28 05:49:40 EST 2006
On 1/27/06, Patricio Antonio Toledo Peña <patricioantoniotoledo at gmail.com>
wrote:
> dear grass list,
> i have two points, they do not belong to a vector map, i have found that i
> can obtain the distance (in UTM and LAT/LONG locations) with this (ugly)
> trick
> grass$ r.profile map=rmap profile=x1,y1,x2,y2 2> temp_file
> grass$ distance=$(awk '/length/{print $4}' < temp_file)
> this method needs a query to a raster map, which is unnecessary, is
> something like d.measure available in r.* commands?
> Thanks in advance
> Patricio Toledo
Try d.geodesic.
*d.geodesic* - Displays a geodesic line, tracing the shortest distance
between two geographic points along a great circle, in a longitude/latitude
data set. (from the grass 6 manual)
Odoardo Zecca
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060128/b3b58c38/attachment.html
