[GRASS-user] Re: proximity mapping / site clustering
    Dylan Beaudette
    dylan.beaudette at gmail.com
    Fri Jul 21 18:43:29 EDT 2006
This sounds like a fun job for GRASS-R coupling!
sample case with the spearfish dataset and the vector 'bugsites'
#GRASS6.1
v.out.ascii bugsites > bugsites.xy
start R:
x <- read.table('bugsites.xy', sep="|")
names(x) <- c('easting', 'northing', 'cat')
y <- data.frame(x[,1:2])
library(cluster)
y.pam <- pam(y, 5)
plot(y, col=y.pam$clustering, main="Bugsites Spatial Clustering, 5 classes",
cex=0.5, pch=16)
#the centroids of the clustering
points(y.pam$medoids, pch=15, col=1:5)
y$cluster <- y.pam$clustering
y$orig_cat <- as.numeric(row.names(y))
write.table(y, file='bugsites.clust', row.names=FALSE)
#back in GRASS6.1
v.in.ascii in=bugsites.clust out=bclust fs=" " columns='x double, y double,
cluster integer, orig_cat integer' skip=1
#display the clustered data with convex hulls:
d.rast elevation.10m
# there are 5 clusters
for x in `seq 1 5`
do v.extract --o in=bclust where="cluster=$x" out=bclust_$x
v.hull in=bclust_$x out=bclust_hull_$x; g.remove vect=bclust_$x
d.vect bclust_hull_$x
done
#display the clustered points
d.vect bclust icon=basic/box fcol=blue col=blue size=5
#note that in the attribute table there exists the original CAT and spatial
cluster number:
 v.db.select bclust
cat|x|y|cluster|orig_cat
1|590232|4915039|1|1
2|590430|4915204|1|2
3|590529|4914625|1|3
4|590546|4915353|1|4
5|590612|4915320|1|5
6|590744|4915535|1|6
just for fun, here is a link to the image.
http://169.237.35.250/~dylan/temp/spatial_clustering_idea1.png
Cheers,
Dylan
On Friday 21 July 2006 14:33, M S wrote:
> followup/correction.
> The "hubbing" does not have to occur along the optimal route (steiner
> tree).  this is "line of sight" orientated (cell towers as example).
> On 7/21/06, M S <mseibel at gmail.com> wrote:
> >  So far the network engineer/planner (who happens to be my Dad) I have
> > been working with on using GRASS for WAN Network engineering and design
> > has been working out awesome.  After a successful steiner tree, i have
> > come to another problem to solve with GRASS.
> > i have all these sites on the minimal connection network.  what i need to
> > do now on a simplistic level, is cluster the sites or aggregate them.
> > Clustering them by proximity is the first step, even though traffic
> > generation is another factor that will have to be added.
> > I have looked at v.net.iso and v.net.alloc, but none seem to produce the
> > results sought after.  is there a function or combination of functions
> > that might cluster sites on the network based upon their proximity to
> > each other?
> > i used v.net.iso with roughly a mile iso band.  i was able to highlight
> > on the optimal network all sites within a mile of each other but those
> > were not the desired results.
> > Any ideas?
> > thanks in advance
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
