[GRASS-user] r.in.onearth downloading problem
maning sambale emmanuel.sambale at gmail.com
Fri Jun 2 04:02:02 EDT 2006
Dear list,
I can't make r.in.onearth to work.  Can someone please help out?
I'm currently using grass6.1cvs 8 under cygwin using hudae's binaries.
 I then downloaded wget for the r.in.onearth script.  I am behind a
proxy server in our office.  I suspect it maybe a proxy configuration
problem.  Any tips on how to do this?  I keep on googling but I can't
seem to get a straightforward answer.  I'm using cygwin primarily due
to GRASS so i'm not really good at cygwin configurations.
Here is the ouput log:
LatLong wgs84 bounding box = N 17.73687406 S 17.67114353 W
121.81056345 E 121.87773668
Will download and import LandsatTM Data with band Red
************** DOWNLOAD DATA ****************
Requesting Data from http://wms.jpl.nasa.gov/wms.cgi
--15:55:00--  http://wms.jpl.nasa.gov/wms.cgi
           => `/home/grass_ppls/fragtest/.tmp/maning_personal/2660.0/Image_global_mosaic_base_Red_241_236'
Resolving wms.jpl.nasa.gov... failed: Unknown host.
!--------------ERROR-------------------!
wget was not able to download the data
Finished
Thank you in advance,
Maning
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |Philippine Biodiversity Web Map                           |
| _)_/LI  |www.geocities.com/esambale/philbiodivmap/philbirds.html   |
