[GRASS-user] Freetype fonts in gis.m
Fri Jun 9 16:07:20 EDT 2006
Michael Barton wrote:
> >> There should be an option to set the default font. You would need to
> >> reset the font after calling anything which might change it (which
> >> includes all command layers, as there's no reliable way to determine
> >> whether a particular command will change the font).
> > I'd only put it at the startup/d.erase stage. If the user wants to call
> > something that changes the font, then let them have that control.
> That can be done now--albeit manually--by changing the listing in
> options.tcl. It is a relatively straightforward project to create an
> interactive window that would let users change some of the settings in
> options.tcl.
I'm referring to the font used for text in modules such as d.text,
d.legend etc.
