[GRASS-user] Freetype fonts in gis.m
Michael Barton michael.barton at asu.edu
Fri Jun 9 18:45:33 EDT 2006
I also was confusing d.text.freetype with d.font.freetype.
AFAIC, all such text should be rendered separately from the geospatial data
itself. That is, fonts and decorations should be rendered as a separate
layers (as they do now). Currently, the only way to have them produce
high-quality output is to render them in the GUI (e.g., as TclTk postscript
objects). Could the relevant d.* commands (e.g., d.legend, d.text, d.label)
be changed to optionally output postscript some something that would scale
and display well? Or does this need to be done in the GUI?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Fri, 9 Jun 2006 21:07:20 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Hamish <hamish_nospam at yahoo.com>, <grassuser at grass.itc.it>
> Subject: Re: [GRASS-user] Freetype fonts in gis.m
> Michael Barton wrote:
>>>> There should be an option to set the default font. You would need to
>>>> reset the font after calling anything which might change it (which
>>>> includes all command layers, as there's no reliable way to determine
>>>> whether a particular command will change the font).
>>> I'd only put it at the startup/d.erase stage. If the user wants to call
>>> something that changes the font, then let them have that control.
>> That can be done now--albeit manually--by changing the listing in
>> options.tcl. It is a relatively straightforward project to create an
>> interactive window that would let users change some of the settings in
>> options.tcl.
> I'm referring to the font used for text in modules such as d.text,
> d.legend etc.
