[GRASS-user] i.vpoints
Wed Jun 28 07:18:16 EDT 2006
Paul Kelly wrote:
> > I haven't seen a GUI solution to force a terminal start, so I'm
> > going to revert the G_parser() change for i.vpoints, i.points, and
> > r.digit.
> Not totally sure what you mean but does
> GRASS_UI_TERM=1
> export GRASS_UI_TERM
> not do this? Stops a Tcl/Tk dialog box popping up and the old command
> line parser interface appears anyway.
Yes! Exactly what I need. Thanks.
I've reworked lib/init/grass-run.src  (-> $GISBASE/etc/grass-run.sh)
see below
It still doesn't work 100% (from gis.m i.group doesn't find maps*,
r.digit can't find selected monitor), but it lets us have those modules
use G_parser().
[*] I_get_group_ref() fails if @mapset is attached to group name, I
should have this fixed soon.
To prevent the GUI startup from the command line, in each term-only module
we can add:
    /* must run in a term window */
    setenv("GRASS_UI_TERM","1",TRUE);
before  G_gisinit (argv[0]);
ie these ones:
g.access
g.setproj
d.font
r.digit
r.le.setup
d.rast.edit
i.points
i.vpoints
i.ortho.photo
i.class
look ok?
Hamish
==== grass-run.sh ==================================================
#!/bin/sh
# script to launch GRASS commands
# force command line startup mode
GRASS_UI_TERM=1
# workaround for systems with xterm is setuid/setgid
#  http://grass.itc.it/pipermail/grass5/2004-September/015409.html
LD_LIBRARY_PATH_VAR=$GRASS_LD_LIBRARY_PATH
export LD_LIBRARY_PATH_VAR
# run command
EXIT_VAL=$?
if [ $EXIT_VAL -ne 0 ] ; then
   echo
   echo "ERROR: $1 exited abnormally. Press <enter> to continue."
   read
fi
exit $EXIT_VAL
