[GRASS-user] i.vpoints
Wed Jun 28 11:25:16 EDT 2006
Hamish wrote:
> To prevent the GUI startup from the command line, in each term-only module
> we can add:
>     /* must run in a term window */
>     setenv("GRASS_UI_TERM","1",TRUE);
> before  G_gisinit (argv[0]);
setenv() is a BSD-ism; please use putenv() instead.
