[GRASSLIST:10782] Re: issues with grass-6.1.cvs-i686-pc-linux-gnu-01_03_2006: nviz does not work
Vishal Mehta vishalm1975 at gmail.com
Mon Mar 6 23:12:42 EST 2006
wow, thats a lot to digest for a linux newbie(me:)
ok, i'll get a Linux friend here to help me try out your suggestions:
thanks all!
vishal
On 3/7/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> On Mon, 6 Mar 2006 17:23:57 -0300
> "Carlos \"Guâno\" Grohmann" <carlos.grohmann at gmail.com> wrote:
> > one can't install qgis-grass-plugin because it depends on
> > libgdal1-grass.
> > libgdal1-grass:
> >  Depends: libgdal1c2 (>=1.2.6) but it is not installable
> > why? because there is no package called ligdal1c2, but there is
> > ligdal1c2a....
> Carlos,
> Build gdal-grass from source then. Fetch it from here:
> http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
> I've been using it. No problems. IMHO it is easier and safer to:
> 1. build Gdal from source
> 2. build Grass from source
> 3. build Gdal-Grass plugin from source
> 4. build Qgis from source
> (3 and 4 order doesn't really matter)
> Than to proceed as you suggest:
> > 1 - install GDAL via synaptic
> > 2 - compile GRASS from source
> > 3 - remove GDAL via synaptic
> > 4 - compile GDAL from source (use --with-grass=path-to-your-install)
> > 5 - compile GRASS again with your new GDAL
> > 6 - compile QGIS (use --with-grass=path-to-your-install).
> I also recommend using checkinstall->dpkg instaed of plain "make
> install". Using custom debs is good better software management and
> sanity.
> Note: I have just noticed a newer gdal-grass plugin version of March
> 1st:
> http://www.gdal.org/dl/gdal-grass-1.3.1.2.tar.gz
> Anybody knows if it is recommended? 1.3.1.1 is OK for me by now. Does
> anybody know what are the changes?
> Maciek
> http://www.visanen.pl/  - Zapakujemy wszystko!
> Produkcja i dystrybucja torby foliowe, papierowe, reklamówki, opakowania
> kartonowe, ekskluzywne pudełka
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060307/ef32700a/attachment.html
