[GRASS-user] How to JOIN a table to vector layer using MySQL
Moritz Lennert mlennert at club.worldonline.be
Thu Nov 9 05:24:05 EST 2006
Raffaele Morelli wrote:
  > The solution would be to work with views.
> Grass sees views, connects to views and this is wonderful, but... more
> it would be if it could handle them correctly. I tried to link to views
> but quering on the attributes doesn't work correctly.
I use views successfully quite often with the postgres driver. Could you
be more specific about what does not work for you ?
Moritz
