[GRASS-user] grass 6.2 won't open gui on macOSX
Michael Perdue michael_perdue at yahoo.ca
Tue Nov 28 01:08:17 EST 2006
Hi Chris,
I had the same problem after installing OSSIM and in my case it
turned out to be because my gdal installation was modified. Can't
tell you how or why as I'm still pretty green when it comes to mac
OSX, but the frameworks seem to be really sensitive and even small
changes will fubar things. If you have the same issue I had then
you'll see a bunch of missing dylib errors when you try running a
gdal command (you can try gdalinfo --formats). In my case I trashed
all my frameworks and reinstalled them from scratch which solved my
problem. Kind of a "bull in a china shop" approach, but it worked.
Maybe someone more knowledgeable than I can offer you a more elegant
solution.
cheers,
Mike
On 27-Nov-06, at 4:57 PM, chris kahler wrote:
> Hi,
> I notice windows users have listed a few problems like mine.
> I'm running OS 10.4 and have installed all
> the
> latest frameworks I could find.
> The error I get is:
>           Mapset <PERMANENT> in Location <newlocation>
> GRASS 6.2.0 > Error in startup script: can't read "parts(n)": no
> such variable
>     while executing
> "MapCanvas::zoom_new $mon $parts(n)
> $parts(s) $parts(e)  $parts(w) $parts(nsres) $parts(ewres)"
>     (procedure "MapCanvas::zoom_gregion" line 11)
>     invoked from within
> "MapCanvas::zoom_gregion $mon"
>     (procedure "MapCanvas::create" line 40)
>     invoked from within
> "MapCanvas::create"
>     (procedure "Gm::startmon" line 11)
>     invoked from within
> "Gm::startmon"
>     (procedure "Gm::create" line 69)
>     invoked from within
> "Gm::create"
>     (procedure "main" line 30)
>     invoked from within
> "main $argc $argv"
>     (file "/Applications/grass6_2/GRASS.app/Contents/Resources/etc/
> gm/gm.tcl" line 521)
> I tried re-installing GRASS as well as making a new location.
>  This helped some windows users sort out
> their errors but I'm still getting the error.
> Regards,
> Chris Kahler
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
