[GRASS-user] gis.m: file ppm not found
Michael Barton michael.barton at asu.edu
Fri Jan 12 17:10:37 EST 2007
Eric, Agustin, and Martin,
I've tried some tests and here's what I get.
If I change the name of a vector file that is listed in the GIS Manager
layer tree, I get an error in the console that says 'file &.ppm not found'.
The display does not change. That is, if a vector was displaying initially
and you change it's name, it still shows as before. If you try to change
anything on its display, the changes don't show up--it simply continues to
display as before. If you try to display a new vector with an incorrect
name, it simply doesn't display. I can add a line to commonlayer.tcl that
will change the error to 'file [vector] not available'.
However, I'm concerned that what I'm seeing is not the problem you are
reporting. I get no crashes, no lockups. Correct files continue to display
fine. Only the misnamed vector file does not display.
Is this what you folks are getting or is it something else?
Michael
On 1/12/07 7:32 AM, "Patton, Eric" <epatton at nrcan.gc.ca> wrote:
> I noticed this ppm problem after I had added a vector to gis.m, renamed the
> table in sqlite (for whatever reason), and attempted to redisplay the vector
> without updating the database connection. I think it can also reproduced by
> adding a vector to gis.m, then renaming the vector using g.rename, and
> refreshing the map display while leaving the old vector name in the gis.m
> table of contents.
> ~ Eric.
> -----Original Message-----
> From: grassuser-bounces at grass.itc.it
> To: Michael Barton; Martin Wegmann; grass user
> Sent: 1/12/2007 6:24 AM
> Subject: Re: [GRASS-user] gis.m: file ppm not found
> Hi all,
> I've found the same problem after compiling the January 6 snapshot in
> a ppc Mac with XCode provided by www.kyngchaos.com. In my case the
> same mapsets work with Grass6.2 and the latest 6.3 binary from the
> www.kyngchaos.com.
> Agustin
>> Since this works with Spearfish but not with some other locations,
> my first
>> suspect would be a permissions problem.
>> To do the graphic display, the GUI needs to send d.* output to
> *.ppm files
>> in .../$MAPSET/tmp/[userpid] -- whatever is specified by g.tempfile.
>> If there are permission problems, this would not work.
>> Another potential problem might be with the GRASS environmental
> variables
>> that set the output to a PPM file rather than an xdisplay.
>> Michael
>> On 1/11/07 7:51 AM, "Martin Wegmann" <wegmann at biozentrum.uni-
> wuerzburg.de>
>> wrote:
>>> Hello,
>>> I did a GRASS 6.3 cvs update one hour ago and now I cannot
> display maps
>>> (raster/vector) anymore. The error message "file *.ppm not found"
> appears.
>>> But that happens only in some locations, if I use spearfish it
> works fine.
>>> BTW I can display my maps via d.mon-d.rast commands hence I think
> it is a
>>> gis.m problem.
>>> any idea, how to fix this?
>>> thanks in advance, Martin
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics and Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
> Dr. Agustín Diez Castillo
> Departament de Prehistòria i Arqueologia
> Universitat de València    Phone:   +34 963 86 42 42
> Avda. Blasco Ibañez, 28   Fax:      +34 963 86 42 34
> València 46010
Center for Social Dynamics & Complexity
phone: 480-965-6213
fax: 480-965-7671
