[GRASS-user] Re: gis.m: file ppm not found
Stefan Paulick stefan.paulick at urbeli.com
Fri Jan 12 18:45:30 EST 2007
Sorry Michael,
the names were untouched since creation.
Full accessibily is granted due to the fact that I am working as root on the
system.
Did you have a look at the faulty mapset? I wonder if the error can be
transported. (www.urbeli.com/grass/grassuser_err.tar.gz)
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
Michael Barton schrieb:
> Eric, Agustin, and Martin,
> I've tried some tests and here's what I get.
> If I change the name of a vector file that is listed in the GIS Manager
> layer tree, I get an error in the console that says 'file &.ppm not found'.
> The display does not change. That is, if a vector was displaying initially
> and you change it's name, it still shows as before. If you try to change
> anything on its display, the changes don't show up--it simply continues to
> display as before. If you try to display a new vector with an incorrect
> name, it simply doesn't display. I can add a line to commonlayer.tcl that
> will change the error to 'file [vector] not available'.
> However, I'm concerned that what I'm seeing is not the problem you are
> reporting. I get no crashes, no lockups. Correct files continue to display
> fine. Only the misnamed vector file does not display.
> Is this what you folks are getting or is it something else?
> Michael
> On 1/12/07 7:32 AM, "Patton, Eric" <epatton at nrcan.gc.ca> wrote:
>> I noticed this ppm problem after I had added a vector to gis.m, renamed the
>> table in sqlite (for whatever reason), and attempted to redisplay the vector
>> without updating the database connection. I think it can also reproduced by
>> adding a vector to gis.m, then renaming the vector using g.rename, and
>> refreshing the map display while leaving the old vector name in the gis.m
>> table of contents.
>> ~ Eric.
>> -----Original Message-----
>> From: grassuser-bounces at grass.itc.it
>> To: Michael Barton; Martin Wegmann; grass user
>> Sent: 1/12/2007 6:24 AM
>> Subject: Re: [GRASS-user] gis.m: file ppm not found
>> Hi all,
>> I've found the same problem after compiling the January 6 snapshot in
>> a ppc Mac with XCode provided by www.kyngchaos.com. In my case the
>> same mapsets work with Grass6.2 and the latest 6.3 binary from the
>> www.kyngchaos.com.
>> Agustin
>>> Since this works with Spearfish but not with some other locations,
>> my first
>>> suspect would be a permissions problem.
>>> To do the graphic display, the GUI needs to send d.* output to
>> *.ppm files
>>> in .../$MAPSET/tmp/[userpid] -- whatever is specified by g.tempfile.
>>> If there are permission problems, this would not work.
>>> Another potential problem might be with the GRASS environmental
>> variables
>>> that set the output to a PPM file rather than an xdisplay.
>>> Michael
>>> On 1/11/07 7:51 AM, "Martin Wegmann" <wegmann at biozentrum.uni-
>> wuerzburg.de>
>>> wrote:
>>>> Hello,
>>>> I did a GRASS 6.3 cvs update one hour ago and now I cannot
>> display maps
>>>> (raster/vector) anymore. The error message "file *.ppm not found"
>> appears.
>>>> But that happens only in some locations, if I use spearfish it
>> works fine.
>>>> BTW I can display my maps via d.mon-d.rast commands hence I think
>> it is a
>>>> gis.m problem.
>>>> any idea, how to fix this?
>>>> thanks in advance, Martin
>>> __________________________________________
>>> Michael Barton, Professor of Anthropology
>>> School of Human Evolution & Social Change
>>> Center for Social Dynamics and Complexity
>>> Arizona State University
>>> phone: 480-965-6213
>>> fax: 480-965-7671
>>> www: http://www.public.asu.edu/~cmbarton
>>> grassuser mailing list
>>> grassuser at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grassuser
>> Dr. Agustín Diez Castillo
>> Departament de Prehistòria i Arqueologia
>> Universitat de València    Phone:   +34 963 86 42 42
>> Avda. Blasco Ibañez, 28   Fax:      +34 963 86 42 34
>> València 46010
> Center for Social Dynamics & Complexity
> phone: 480-965-6213
> fax: 480-965-7671
