[GRASS-user] xwindow, dhcp and grass
Gerald Nelson gnelson at uiuc.edu
Sun Jan 21 14:14:27 EST 2007
More updates.
d.mon displays a window.
gis.m displays the Output window and the map logo window. But doesn't display the window where you can actually do things. And when I type say g.list in the xterm window, nothing happens.
Jerry
---- Original message ----
>Date: Sat, 20 Jan 2007 23:57:02 +0000
>From: Glynn Clements <glynn at gclements.plus.com>
>Subject: Re: [GRASS-user] xwindow, dhcp and grass
>To: Gerald Nelson <gnelson at uiuc.edu>
>Cc: grassuser at grass.itc.it
>Gerald Nelson wrote:
>> This question is only partially related to grass. I'm currently in
>> Rome (at FAO) for a couple of months and want to use xwindows on my
>> laptop to access my linux box with grass on it back home in the
>> states. I'm staying in an apartment that uses a usb ADSL connection
>> (tisoli for those who might know about this). I have tried the
>> following.
>> 1. run xming with the default settings created with xlaunch (starts a passive x server)
>> 2. run either putty or ssh with x tunneling turned on
>> 3. in the terminal window I can type xclock & and the little clock window shows up.
>> However, when I type grass63, choose my region and then gis.m, if I
>> get anything it takes a LOOOOOONG time for the logo window to appear
>> and the output window, but the gui never shows up.
>> Any tips on how to do this appreciated. Do I need to set the DISPLAY
>> variable on the linux box? Any other settings I should know about?
>The only other thing which I can suggest is to enable "trusted" X11
>forwarding in ssh, using "ssh -Y" (rather than "ssh -X") or by setting
>ForwardX11Trusted in the client config file.
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
