[GRASS-user] Error configuring grass-gdal 1.3.2: grass libs not found
Patton, Eric epatton at nrcan.gc.ca
Tue Jan 23 12:52:08 EST 2007
I tried rebuilding Grass (make distcleaning first) and reinstalling the gdal plugin with the same error. What's the recommended way of starting from scratch so that all gdal-related files are removed?
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: grassuser at grass.itc.it
Sent: 1/23/2007 11:20 AM
Subject: Re: [GRASS-user] Error configuring grass-gdal 1.3.2: grass libs not found
Patton, Eric wrote:
> configure: error: --with-grass=/usr/local/grass-6.3.cvs requested, but
> libraries not found!  Perhaps you need to set LD_LIBRARY_PATH to
include
> /usr/local/grass-6.3.cvs/lib?
Eric,
This suggestion is just a perhaps.  Generally it means things failed
to link and you can dig into the config.log to find out details.  I
suspect the problem is that grass is built against the old GDAL so
attempts to link the driver against grass libraries fails because the
old gdal library can't be found.
If that is the problem, you may need to rebuild and install GRASS using
the new GDAL libraries before trying to rebuild the grass-gdal driver.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
