[GRASS-user] Error configuring grass-gdal 1.3.2: grass libs not found
Jaros?aw Jasiewicz jarekj at amu.edu.pl
Wed Jan 24 03:10:01 EST 2007
Patton, Eric napisa?(a):
> I recently had to recompile gdal so that support for ECW was enabled. I decided since I was changing my compile line, I would upgrade from gdal-1.3.2 to gdal-1.4.0 in the process. I ran make distclean in my gdal-1.3.2 directory, then configure, make, and make install in gdal-1.4.0, all of which proceeded without errors. gdalinfo --formats reports a normal listing of supported file types. Grass compiles and installs normally as well.
Do:
./configure --with-grass=/usr/local/grass-6.3.cvs --with-libgrass=/usr/local/grass-6.3.cvs/lib/
ubuntu or mandriva I guess?
> The trouble lies with the gdal-grass plugin. An error occurs during compilation, reporting
> configure: error: --with-grass=/usr/local/grass-6.3.cvs requested, but libraries not found!  Perhaps you need to set LD_LIBRARY_PATH to include /usr/local/grass-6.3.cvs/lib?
> However, my LD_LIBRARY_PATH is set to include my Grass installation driectory:
> $ echo $LD_LIBRARY_PATH
> /usr/local/lib:/usr/lib:/usr/local/IVS/lib:/usr/local/grass-6.3.cvs/
> My /etc/ld.so.conf also includes my Grass lib directory:
> $cat /etc/ld.so.conf
> /usr/local/bin
> /usr/X11R6/lib
> /usr/local/lib
> /usr/lib
> /usr/lib/atlas
> Any suggestions?
> Thanks,
> ~ Eric.
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
